I miss 123d Design (the Fillet master)
9952.58 In reply to 9952.49
@Pilou
>>In the same order of case...
>>curves must be always on the same plane ?
Not so parametrable as Filet, for non planar curves, you can use the Max's "DelCorners" script.
If you want tune how much your curves will be round, you can use, before "DelCorners", a "Rebuild" (with Pts number) to define it.
Few possibilties for this tuning, but : Tested and it works !
I think it's easier than a blending process which has to be done step by step between 2 curves each time.
