Dimensions Feedback and Features
9950.2 In reply to 9950.1
Hi Stefano,
> 1.Is there is a way to set default line colour
> on all dimensions to say 70%black or any other colour (Not 100% black)?
> I understand we can select the line colour for the layer/style they are on
> but I'm hoping for a default global setting...ideally
> one click or in options¿ or could be ok in the ini file.
There isn't any way to do that currently but I will add in an option for that.
> 2. Keyboard shortcuts.
> Can we set up a 2 command shortcut to select say;
> A. horizontal dimension tool
> with subset menu
> B. "from frame" selected
>I'm pretty interested in these 2 command shortcuts.
I'm not quite sure I understand this completely - could you please describe a bit more what you mean by "subset menu", and there isn't any dimension option of "from frame", do you mean "From object" ?
If you mean you want a keyboard shortcut that trigger horizontal dimension with the "From object" mode activated immediately, you can do that by setting up a keyboard shortcut like this:
DimHorizontal FromObject
Put that whole line into the "Command" part of a shortcut key. Then if you preselect a curve clicking on the line segment of interest, you can then press that shortcut key to place a horizontal dimension set to the endpoints of that line automatically without having to click on the points.
You can also set up these for vertical and aligned dimensions:
DimVertical FromObject
DimAligned FromObject
Please let me know if that was not what you were asking about.
