Extrude issue with letter imported from dxf
9946.3 In reply to 9946.1
Hi, Charlie.
In the contour of the letter there are overlays of dots if you remove them everything becomes normal.
If possible, for MoI, transmit via PDF or AI format, so it turns out without overlapping points. This often happens in the dxf.
One of the methods of treatment is to spread the points by height and remove the extra ones either through the rebuild command or export import via PDF or AI format.
