Little trick challenge :)
After a boolean cutting, inset is not a so bad idea.
You could "inset" two or three faces of a solid together to avoid part of the corner problem you had.
For external corner you select together 3 faces, for external egdes, 2 faces and top internal face only one.
Perhaps another way is
-- Copy/paste original solid
-- a boolean cutting with lines
-- explodemove function on cutted solids
-- your copy is inner solid and have to be resized
The problem is : with ExplodeMove you don't have spaces not so regular.
EDITED: 12 Sep 2020 by PHIRO
Size: 245.9 KB, Downloaded: 19 times, Dimensions: 601x401px
Size: 291.9 KB, Downloaded: 25 times, Dimensions: 652x399px
