V4 beta Sep-10-2020 available now
9942.50 In reply to 9942.49
Hi Mik, so Affinity Designer not seeing the AI export is a limitation in Affinity. It doesn't support the older version 8 AI files that MoI writes out.
Affinity Designer only supports the newer AI type file and only then if it was saved out from Adobe Illustrator with the "Create Compatible PDF File" option enabled in Adobe Illustrator's export options. When that is enabled, then the new AI file type is actually a PDF file and then Affinity just reads the PDF content from it.
MoI only exports the old AI version 8 file type because that's the only one that has been documented by Adobe. They have not documented how Adobe Illustrator stores illustrator-specific information in private data inside the PDF structure for the newer AI file type.
So since Affinity does not support the older AI v8 format and MoI only exports AI v8 format, that means that you need to use PDF format for transfer from MoI into Affinity Designer and not AI format.
For the "Preserve units" + "Center on page" bug, if you can send me an e-mail at moi@moi3d.com, I'll send you a test version to test a fix for that.
