V4 beta Sep-10-2020 available now
9942.13 In reply to 9942.12
Hi Burr,
> Just so I am clear, this "Gaurd Rail" function is "NEW", Correct?
Correct.
> So, the mesh angle ini setting is obsolete if you can only set it for a current session
> within the UI.
It still works as before for values between 10 to 45 degrees.
> But the new flag you mention could make it relevant again?
Yes, the new flag that I'll add will make things behave same as before.
