Nudging value increments ?
9940.5 In reply to 9940.3
You can use easily ((?) for that you want yes :) the Elephant system by Max Smirnov! ;)
Here something with Extrude but you can use quasi all functions! Extrude, Offset...etc ;)
You can Input any Increment Value to the Slider by Min Max!
here Min = 0, Max =10, Digit =1 ...so 0.0 0.1 0.2....9.8 9.9 10
See my Repository ;) French / English ;)
Here The Profile (a close curve on the ground) is pre-selected!
A curve closed (or not) existing result will be a solid volume (or a surface)
Select it ...Right Click on the Node "Selected" for Update it (not shown on the video) RUN and move the Slider...
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/extrude_exo.nod
EDITED: 9 Sep 2020 by PILOU
