Offset Inset > save preset
9936.4 In reply to 9936.3
> I suppose that is valuable for the other functions?
> but how to find the other functions' "Syntax" ?
Yes it can work with any command. To find out what parameters are available you can look in the .htm file for the command, the id="" value of the control is what you use.
So for example in the Extrude.htm file the Distance field is this: <moi:DistanceInput id="distanceinput"
So that means that the Extrude command can take a parameter named distanceinput with a number, like distanceinput=3.
If you set up a keyboard shortcut (or type Tab and type it in and push Enter) of: Extrude distanceinput=3 it will be the same as if you ran the Extrude command and then set the "Distance:" field to 3.
To trigger a button you put in just the id value by itself, like: Extrude tapered , that will be the same as if you ran the Extrude command and pushed the "Tapered" button.
Input fields take a number like field=3.2 , checkboxes take a true/false value, dropdown combo boxes take one of the values of the <option> elements inside them.
EDITED: 8 Sep 2020 by MICHAEL GIBSON
