3D Printing - Exported models show as having errors
9935.2 In reply to 9935.1
Hi tofuji, the STL format is only meant to contain one single solid object in it, but your file contains 54 different objects that are partially overlapping each other.
You'll need to get the model cleaned up so that the entire model that you want to export to STL is just one single solid object.
Probably the cleanest way to do that with your current model is to select everything, then run Edit > Separate to break it into individual surfaces, then click on surfaces that are next to each other and after you've built up the selection use Edit > Join to glue them together. That's what I did with the attached 3DM file.
When you select the object, you want the object type to show as "Solid":
If it says it's a "Joined surface" or "Surface" that means it has some areas with a hole where edges are not joined between 2 surfaces.
