New user quick question on Moi3d v4
Hi Matadem,
MOI doesn't able to do an automatic image tracing as seen in your video.
But, you have two possibilities to have the same thing as in the video.
For logo, personnaly, I do the image tracing with Inkscape which is very good to do it (free and opensource).
Next I export it from Inkscape in pdf format.
MOI3D is able to import pdf format and you will have very good results.
At the end, you could extrude as you wanted.
example :
Another possibility is to use the Max's plugin named "heightmap".
You use a bitmap as grayscale map and heightmap do a serie of curves.
WARNING, the program create a curve (or point) for each pixel in X or/and Y.
Next you could loft curves.
At the end you have to cut unnecessary parts.
You have to choose... But first possibility is best for logos and second is used for more complexe (and less sharp) sources/results.
