In case it is relevant, or maybe just a confirmation of your thought about the v4 Esc interrupt mechanism, here is some additional data.
My script uses a 2-stage process to create multiple leaders with coordinate values and as such it makes use of the allowNestedCancel() feature. The desired behavior around Esc/Cancel is to allow more granular cancellations rather than an immediate complete cancellation of the command. The UI Cancel button is working as desired and allows the granular cancellations but the Esc key does not. When the Esc key is pressed in the inner function it triggers a cascade of cancelbutton/cancel events in the same fashion as without allowNestedCancel() & thus an immediate complete cancellation of the command.
It is interesting that without allowNestedCancel() the Esc key throws an exception but with allowNestedCancel() it does not, but in either case the Esc triggers the cascade of cancelbutton/cancel events.
I added some logging with timing data to better understand what was happening and the following log snippets attempt to illustrate the difference between the Cancel button and Esc key. The >> indicates what I did with the UI
With pointpicker.allowNestedCancel()
Test using Cancel button (requires 3 clicks on Cancel to exit
command, desired behavior)
>> Click on object
6465ms: doCoordinates() event: finished
>> Draw out leader, wait, click on Cancel
>> Leader disappears, Pick leader arrow tip is shown
10149ms: trapEsc() canceled: cancelbutton
10149ms: coordinateLeader() event: cancel
>> Wait, click on Cancel
>> Pick next leader point is shown
16373ms: trapEsc() canceled: cancelbutton
16373ms: doCoordinates() event: cancel
23072ms: trapEsc() canceled: cancelbutton
23072ms: coordinateLeader() event: cancel
Test using Escape key (first Escape causes command to exit)
>> Click on object
3465ms: doCoordinates() event: finished
>> Draw out leader, then press Esc
5876ms: trapEsc() canceled: escape
5876ms: coordinateLeader() event: cancel
5911ms: trapEsc() canceled: cancelbutton
5911ms: doCoordinates() event: cancel
5943ms: trapEsc() canceled: cancelbutton
5943ms: coordinateLeader() event: cancel
Without pointpicker.allowNestedCancel()
>> Click on object
4989ms: doCoordinates() event: finished
8470ms: trapEsc() caught
8470ms: coordinateLeader() event: cancel
8505ms: trapEsc() canceled: cancelbutton
8505ms: doCoordinates() event: cancel
8541ms: trapEsc() canceled: cancelbutton
8541ms: coordinateLeader() event: cancel
Code attached if helpful, otherwise I'll continue to look forward to the next beta.
--Larry
