Converting STP to STL format
9911.4 In reply to 9911.3
Hi Ian, for something that large you'll probably need to use a file sharing service and send a link.
With a large file you're probably running into memory limits though. MoI version 3 (which includes the current trial version) is still a 32-bit program and can run out of 32-bit address space when loading in large models.
This is fixed up in MoI version 4 which is now a 64-bit program and also has some other large file handling improvements like using multiple CPU cores to process objects when loading STEP/IGES/SAT/3DM files which improves loading speed by quite a bit (like 4-5x faster or more). Also v4 shows a progress bar while the file is loading instead of the UI just staying frozen while it's busy loading a file as will happen in v3.
With the v3 trial if it looks like nothing is happening but it is still busy using CPU cycles then let it sit for a while and chew on it, it will probably load eventually as long as it doesn't run out of memory.
There are some settings you can adjust for v3 to make it have a coarser display mesh which can help to reduce memory consumption:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5322.2 .
MoI v4 is very nearly wrapped up and I'm hoping to release it at the end of this month. Once that happens then there will be a trial version for it. The beta version is available to V3 owners at https://moi3d.com/beta.htm .
