FAIL TO SHELL
9907.4 In reply to 9907.3
Hi Alex, also it seems that it's a combination of the holes being small and also that they're made up of several edges. If you run the Merge command on your surface that will combine them into one edge and it will shell ok after that.
I've added this case to my list to investigate after v4 is wrapped up to see if I can make the original one work.
