turning off the transform helpers
9905.6 In reply to 9905.5
Understood ! Object dragging rarely gets in the way anyways.
Now for something different : I've been running into a strange behavior causing a vertical ruler to appear unexpectedly, even when all snapping options are turned off :
It seems to be similar to what usually shows up when click-dragging from the right side of the main viewport area (as if trying to modify the width of panels), next to the toolbar.
Admittedly my UI is heavily customized so this might be what is causing this ghost line. Also FWIW I am running a 3-monitor setup, so maybe that's a factor here.
This isn't much of a bother, just a bit annoying when it happens. Any idea as to what could be causing this ?
