Export equidistant curve points ?
9902.14 In reply to 9902.13
Hi Tom,
> That means that I need to export curves with hard edges and than in
> Cinem change them to Splines with rounded egdes - that is the work -
> around, yes ?!
Yes, I think so. If you export a curve that has been converted to only have line segments in it and not any smooth pieces (this kind of curve is called a polyline), then I would think you should not have any variations in point arrangement or density in the transfer.
