Export equidistant curve points ?
9902.1
I want to import curves to Cinema as splines. For an animation I
do need those curves with equidistant points in Cinema respectively
with exactly the same point configur“ration / position as in MOI.
Problem : DXF -export does not have an "equidistant points-options.
I can generate points manually and export them as a txt - file but Cinema
does not import txt.
Question : How can I get curves from MOI with exactly the same point
configuration into Cinema ?
TOM
