| Hi Maysky, if the object isn't an exact circle or polygon then there won't be a center object snap. But there is a command named BoundingBoxCenter that you can use to make the point I think you want. To run it, press the tab key to put keyboard focus in the XYZ input control and then type in BoundingBoxCenter and push Enter. Or you can set it on a shortcut key.
