Boolean Diff leaves holes in planes, not object
9895.7 In reply to 9895.6
you need to build missing faces ( with networks )
copy paste the 2 circles ( to trim later )
I delete the two faces with circles ... select the four borders ( don't forget to join the segments of each border ) and apply Planar ( to prevent possible gaps )
join the 6 faces of the piece ( it says Solid ... good for booleans
paste + trim the circles and the flat faces ( then you can delete the round disks )
and loft between the two circles
finally copy all faces included the round surface ( the loft ) and paste elsewhere ... then join to have a solid
( I work on the half piece and do a mirror + boolean union )
3dm file joined
EDITED: 9 Sep 2020 by CORCHET
