Layer Styles?
9889.4 In reply to 9889.3
Hi Stefano,
> Autocad/dxf
> is there ways (or will there be) to put imported dxf curves info on different moi layers automatically
> on import? Looks like layer names or likely lineweights are favourite.
Yes, that's a new feature in v4 that the DXF importer will read in layers in the DXF file and make styles in MoI from them.
> Illustrator
> I understand the import export is based on eps / ai (vs 8)
> Theres a thread I read somewhere about exporting layers to illustrator.
> by applying styles....once this is set up can moi import layers
> from illustrator?
No, importing and exporting are pretty different things. MoI can export layers to AI v8 format but not read them in from AI as of yet.
> Universal import
> If any comaptible vector document is single page file and has a number or defined "mapped file name syntax" (or simple prefix) say
> ~10filename.eps
> THEN....
> after import those curves are place on moi layer "10filename"
It seems kind of unusual - are there other programs that use certain character sequences in filenames to trigger behavior like this?
I think it would be possible to make a plug-in that would behave like this.
