Hi Frederick, no problem I'm glad you have a method to do it!
I had an idea that maybe drawing a center line as the definition for the slot might be useful.
Here's a script that does it that way:
To give a specific length, set a distance constraint using the "d" field in the bottom command bar.
EDIT: updated command to have radius/diameter toggle and to use diameter as default if set in moi.ini .
