Hi Al, I'm glad that MoI's mesher is working well for you!
It is possible to automate opening and saving of files, except I think that the mesh dialog may be a problem. However, I think it would be fairly easy to tweak things to make that work.
Do you need to adjust different mesh settings (like the angle, etc.. ) through the automation, or will the default settings work ok?
How would you think this should work? Would you want one initial piece of UI that let you pick a folder, and then have every IGES file in that folder converted to an OBJ of the same name?
