4K UHD 15.6" display
9868.2 In reply to 9868.1
Hi Mik, so the things that are too small are some of the remaining things that are drawn from source bitmap images and their on-screen size is taken just as the size of the bitmap image. I'll be making a pass through to convert these sometime after v4 is wrapped up. For now a quick fix is to replace the source images with scaled up versions which I have attached here, these are doubled in size. Put these attached images in place of the original ones which are in the /ui sub-folder inside MoI's main installation folder.
If you want to scale them to some other size than double, the images to convert are:
Please let me know if you see any other things that are too small.
Thanks, - Michael
Edit: Removed PointLabel.png since it was not needed.
EDITED: 7 Jul 2020 by MICHAEL GIBSON
Size: 818 bytes, Downloaded: 58 times, Dimensions: 26x26px
Size: 440 bytes, Downloaded: 43 times, Dimensions: 14x14px
Size: 647 bytes, Downloaded: 44 times, Dimensions: 14x14px
Size: 624 bytes, Downloaded: 38 times, Dimensions: 14x14px
Size: 625 bytes, Downloaded: 30 times, Dimensions: 14x14px
Size: 1 KB, Downloaded: 35 times, Dimensions: 22x22px
Size: 428 bytes, Downloaded: 36 times, Dimensions: 38x38px
