4K UHD 15.6" display
9868.1
Is it possible to change pixel size for graphic items marked by red arrows in attached print screen?
I've found associated rows for Edit frame pixel size and opacity in moi.ini file, but I'm not sure if such possibility is available for mentioned items.
The same "issue" I observed when I draw a point. Point size in pixels is too small for 4K UHD display.
Probably moi.css file would be the right one for such changes, but it will be much appreciated to place here in forum some procedure for optimizing UI for everyone with 4K UHD displays.
It would be great (not necessary) to have similar slider as for UI in Options/General menu.
Thank you.
Mik
P.S. The change the Windows system compatibility settings for high resolution displays in moi.exe file isn't the right way :-) MoI looks great in UHD display, only mentioned graphic items are too small.
Size: 289.6 KB, Downloaded: 149 times, Dimensions: 3840x2160px
