Keyboard Shortcuts two computers
9862.5 In reply to 9862.1
Hi brane, yes if copy over your moi.ini file that will bring all your shortcut key definitions over. You can find out where the moi.ini file is located by using Options > General > "Edit .ini file" button. That will put up a dialog box that tells you where the moi.ini file is located at.
If you have installed any plugin-ins by copying stuff into the commands folder you'll also need to do that on your other machine as well.
