Trivial but...
9857.4 In reply to 9857.3
Hi Pilou, you can do that with the Trim command using the mutual trim option.
Select both objects before running Trim.
The prompt will say: "Select cutting objects or Done for mutual trim". So in this case where you want the objects to be both an object that is being trimmed as well as a cutter for the other, push the Done button (or right-click in a viewport) without selecting anything.
Then pick the pieces to discard and you will have your result.
Here is a demo:
