> Also, when moving objects and right clicking it would be nice to have
> the object return to its original position without activating the previously used tool.
Hi Val, do you mean if you right-click during the middle of object dragging, to cancel the dragging? I'll see if I can tune that up. For the moment use the Esc key instead, it will cancel the drag without repeating the last command.
> Do you want me to upload the file?
Yes, please - that would help clarify things.
But in general it is a limitation right now in MoI that a sweep along a multi-segment rail will process the segments individually.
For v2 I would like to make the one-rail sweep handle mitered corners, but I'm not sure about handling corners for 2-rail sweep. If I can see your example and how it behaves in Rhino it might help me understand what you would like it to do.
