Hi Steve, if these areas are to be flush:
Then I'd probably try something like build an initial surface that extends over to start with, and trim it with your profile:
Then discard this piece:
Then also discard this piece:
Extrude out your profile a larger distance so it goes past the new surface:
Trim it with these as the cutting objects:
Select this as the piece to remove in the Trim:
So then you'll have just one larger surface for the inside like this:
One problem with your original model is that this spot did not go all the way across:
