Fillet lenght problems
9835.1
Dear all,
Does anyone encounter or notice this problem when you apply fillet for a whole box corners.
I explain, if you draw a box of 5mm to be filleting with 2.5mm from each corner.
You can't fillet the corner with that value but if you enter 2.49mm is OK but 2.5mm you can't.
Can you someone explain to me why because if there is a routine in the fillet command is not doing the job.
If you have the fillet command correctly do their job I love to someone send it to me.
Thanks a lot for your help.
