Both sides /cap ends hotkey for offset ?
9832.2 In reply to 9832.1
Hi K3nny, so there are a couple different ways.
You can set up a shortcut key that will always run offset with both sides off like this (in MoI v4):
offset curvebothsides=false
Or always on with this:
Or here is one that will toggle it while you are in the command as if you clicked it. It should work for Offset, Extrude and also the Line command:
script: /* Toggle both sides for offset or extrude */ if ( moi.command.currentCommandName ) { if ( moi.ui.commandUI.curvebothsides ) moi.ui.commandUI.curvebothsides.click(); if ( moi.ui.commandUI.bothsides ) moi.ui.commandUI.bothsides.click(); }
A toggle for cap ends would be like this:
script: /* Toggle cap ends for offset or extrude */ if ( moi.command.currentCommandName ) { if ( moi.ui.commandUI.curvecapends ) moi.ui.commandUI.curvecapends.click(); if ( moi.ui.commandUI.capends ) moi.ui.commandUI.capends.click(); }
