Sweep Mystery
If it could help, to explore this mystery, when you move a point which is not a sweet point, the sweep is capped.
The path is made with hard and soft points with lines and curves joined.
If you use a rebuild fuction, the problem is resolved.
If you use a ReconstructCurve, it's solved too.
If you use the script delcorners, it's solved too.
Michael, is it possible to view the different types of points in MOI ?
Soft, Hard and those are semisoft/semihard ?
