Make2D - merge overlapping lines
9811.1
Hello everybody
I like to use the function "make2d" to project two-dimensional drawings from 3D bodies in the different views.
This often results in lines lying on top of each other.
Is there a way how to merge overlapping lines, which are similar up to a certain tolerance, to one line?
An hour later:
Now I have found out that 2 curves lying exactly on top of each other can be merged with the "booleanmerge" command.
The calculation time depends on the resolution setting. However, if the two curves do not have the same length, for example, the merge will not work.
Here something else would be required.
Thanks for a hint.
Franz
EDITED: 19 May 2020 by FRANZ
