[Node Editor] Script Error
9810.6 In reply to 9810.5
Hi Smoluck, well I was able to get that all set up but I can't seem to trigger the error:
Earlier I wrote:
> The code there looks kind of dubious, it looks like it is making an object list but not adding any objects
> to it before trying to get the bounding box. It probably needs a little tuneup.
This was wrong, but there is a bug somewhere in the works there where under some particular condition there isn't an object list being returned out there like the rest of that node's code is expecting. Probably.
If you can figure out a consistent way to reproduce it, then I would have a good shot at figuring it out.
> to be honnest i'm really interested in the Node Editor instead of the direct tool.
> (wich is maybe an error, but procedural is my passion)
Well, possibly, but not necessarily. It kind of depends on what you're looking for. If you're interested in something open source and where it's a small community and you would like to help move it along then you might be in the right spot. If you want something with tutorials and documentation and resources (like training and books) then probably not, Rhino+Grasshopper would be a better fit.
