[Node Editor] Script Error
9810.4 In reply to 9810.1
Hi Franck, what version of the node editor are you using? Can you post a .zip file of your node editor folder so I can test with the same version you are using?
The code there looks kind of dubious, it looks like it is making an object list but not adding any objects to it before trying to get the bounding box. It probably needs a little tuneup.
