Is there an Object Name "Search & Replace" script available?
9791.2 In reply to 9791.1
Hi Tom, thanks for all your great work with YouthQuest!
For search & replace, I've attached 2 scripts here which can help.
The first one "BatchRename" is for object names, the second one is for style names.
The way the script works is that it will gather up all object names and write them out to a text file.
Then you can open that text file in any text editor you want and make modifications. When you're done editing the text file then push "Done" and the script will read the text file back in and apply any changes to object names.
Hope that does what you need!
