Easy way to select Fillet Faces?
I’m looking for a way to easily select the faces that make up a Fillet immediately after creation.
Often I need to assign a different color to the fillet only. Example: A fillet around a car window needs a unique color so a chrome trim material can be assigned in the render program.
Clicking around to select all the fillet faces gets tedious. Is there a script that remembers and highlights the faces the Fillet just created?
I’m looking for similar behavior as when you construct a Loft. Upon completion of a Loft, the curves remain selected.
- Ed Ferguson
