Custom UI / Shortcut setup - step by step
9769.2 In reply to 9769.1
Hi SADOOO, what version of MoI are you using and what operating system?
re: "All the shortcuts" - there isn't really such a thing, shortcuts can contain script code in them and so there isn't a fixed number of them.
Check out here for some previous discussion:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9680.2
To install shortcuts you could either copy the entire moi.ini file over top of your current one, or you can open moi.ini in a text editor and copy/paste the shortcut keys section.
You can see where moi.ini is located by using Options > General > "Edit .ini file" button. That will put up a dialog that has the location of the moi.ini file that is being used on it and if you continue it will open it up in a text editor for you to edit it.
Some shortcuts can contain script code directly in the shortcut key definition. For that type once you set up the shortcut key it's ready. Some shortcuts may be referring to plug-ins and you will also need to install the plug-in for it to work.
