Hello corchet .... I know the procedure .... I have to make a bend in the surface .... I can do the hole ... maybe I explained myself wrong I wanted to know if there is a command that closes the hole creating me a crack but closed not open.
Usually I cut the surface then I lower it and finally use the blend command but this shape must necessarily be pointed like on both sides and I thought of making that shape to intersect with the surface and then subtract it and then use fillet but I can't place it on the surface
