Flow command
9766.3 In reply to 9766.2
1) I have selected the surface
2) Flow
3) selected the center line of the right surface
4) selected the line on the left surface
Usually I project a curve on the surface .... then I cut and lower the cut surface and use the blend command but I had problems with the shape of the cut which is quite pointed in the ends ... for this I asked if there is a specific command or a technique that maybe I don't know
