Flow command
9766.1
Hi guys I should create a crack on this surface I had thought of using the flow command to make it ... I built more or less the shape of the side crack but using the flow command it does not place it on the surface.
Do you think it is the right technique or could it be done with a different command?
Size: 964.2 KB, Downloaded: 56 times, Dimensions: 1600x1200px
