MOI Amazing
9743.7 In reply to 9743.6
Hi Tim, if you can post your modified CommandBar.htm and SidePaneFilename.htm files here as a file attachment I can check them out to see if they are set up ok.
> but even after replacing the command bar htm I am still missing the full screen toggle?
The full screen toggle is only shown if the window is maximized and on a screen that has a Windows taskbar on it. If your window is not maximized or not on a monitor with a task bar then it is normal that it will not show up.
