Hi Tony,
> is there a command that develops the surface of a tire to make the flow command faster?
There isn't any special command for a tire but you can use some of the Transform > Array tools for making a repeating pattern of object copies.
> I also tried the unwrap curve script but it doesn't work
Was there any error message displayed? Did you select a curve first before running it?
