AssignName
9717.7 In reply to 9717.1
Hi Rudl,
> Where must I place the AssignName Script. I get an error, when ich want to open it.
That error means that it is not installed in a location where MoI looks for command files.
There are 2 places you can install it to, either the commands sub-folder in the main install folder, or for v4 another option is in the Moi appdata commands folder. If you are using v4 the latter is recommended since that is a centralized location apart from any individual program version and so it will be found there when you install new versions.
To find your MoI appdata commands folder, go to your system's appdata folder which on Windows can be found by typing in %appdata% inside the start menu or Win+R Run dialog, or on Mac it's under ~/Library/Application Support.
Inside the system appdata folder go into the Moi folder, then inside there go to commands. That's where you want to copy the unzipped files into.
