Smooth curve which comes from OBJ import
9713.6 In reply to 9713.1
Like corchet writes above though, there are some gaps between line segments that are too large for it to be treated as a single polyline though.
If the data was good enough you would use Edit > Join to make it into a polyline, then Rebuild with "Endpoints" mode.
Also another problem with the data is the areas that should be smooth do not have enough refinement, there is about the same angle between different segments as there is for lines within a smooth segment.
With really rough sparse data like that with gaps between pieces there isn't really going to be an automatic process in MoI to handle that.
