Rotate Array?
9710.1
Hello MoI friends,
I am wondering if anyone can help me with a fairly simple, but seemingly complex request please?
I am trying to achieve a 2D task that I cannot achieve in Illustrator (but should be able to!) and have come very close to achieving what I want to achieve with MoI. I'm wondering if there was ever a script created that was similar to the existing "Scale Array"? What I need is exactly the same, but instead rotating each array instance by a certain degree angle. I have enclosed a screenshot of what I mean...
So I would like to Array 17 copies (18 total) of the initial blue leaf, with the final leaf matching the angle of the red leaf and the instances (black) morphing between the two. As you can see, I have got very close to what I am trying to achieve with Array Curve and Scale Array. I just need to be able to incrementally adjust the angle of the leaves in between to achieve the 18th leaf as the red leaf, instead of the green leaf.
I'm sorry if I have over-complicated that? I think my diagram should visually explain what I am trying to achieve?
Thanks as always and hopefully one of you bright geniuses will have an idea or a solution?
I did have a look at the two Scale Array files in the hope of adapting them to rotate instead of scale, but sadly it's slightly more advanced than I am capable.
Many thanks,
Tim
