Some idea ?
9703.2 In reply to 9703.1
Hi Pilou, the Flow command works by constructing new surfaces, fitting and refining them to match the Flow deformation (except for with "Rigid" mode). It's built into it that it refines (and thus adds more points) as needed so the surface shape matches a target tolerance value.
It is not a command that is focused on preserving the control point structure of the surfaces being deformed.
