Batch Convert STP to FBX
9695.2 In reply to 9695.1
Hi ironsightdesign, I think the problem is in your BatchConvert.js file, you've got to move this: ConvertFolder( 'd:\\_convert', 'stp' ); to the bottom, right now it's located inside the ConvertFolder function itself so that's going to be an infinite loop.
So like this:
BatchConvert.js
// This is the script file that you would generate, put one line in
// for each file you want to convert.
#include "Convert.js"
function ConvertFolder( FolderName, FileExtensionToLoad )
    // Convert all files within a given folder, that have the given file extension.
    // For example, convert all .3dm files inside of the folder c:\test :
    // ConvertFolder( 'c:\\test', '3dm' );
    // Not right here though!
    //ConvertFolder( 'd:\\_convert', 'stp' );
    var Files = moi.filesystem.getFiles( FolderName, '*.' + FileExtensionToLoad );
    for ( var i = 0; i < Files.length; ++i )
        Convert( Files.item(i) );
// Put it here:
Let me know if you're still stuck. If so maybe post your .js files as a file attachment.
