Batch Convert STP to FBX
9695.1
I've been trying to piece together code for a script to batch convert over 200 .stp files to .fbx, but cant seem to get it working.
These are my scripts (inside a "scripts" folder in the MOI program files directory, called with a shorthcut:
BatchConvert.js
// This is the script file that you would generate, put one line in
// for each file you want to convert.
#include "Convert.js"
function ConvertFolder( FolderName, FileExtensionToLoad )
// Convert all files within a given folder, that have the given file extension.
// For example, convert all .3dm files inside of the folder c:\test :
// ConvertFolder( 'c:\\test', '3dm' );
ConvertFolder( 'd:\\_convert', 'stp' );
var Files = moi.filesystem.getFiles( FolderName, '*.' + FileExtensionToLoad );
for ( var i = 0; i < Files.length; ++i )
Convert( Files.item(i) );
Convert.js
function Convert( FileName )
var gd = moi.geometryDatabase;
// Open the file, set 2nd param to true to suppress any save changes prompt.
gd.open( FileName, true );
// Create the output file name by breaking off the file extension and adding 'obj'.
FBXFileName = FileName.substr( 0, FileName.lastIndexOf('.') + 1 ) + 'fbx';
// Save out to the output file, passing the option to suppress the UI. You
// add other options separated by semi-colons with no spaces. These
// options are available for controlling the meshing:
// NoUI=true
// Angle=12.0
// Output=ngons | quads | triangles
// MaxLength=0.0
// MaxLengthApplyTo=curved | planes | all
// MinLength=0.0
// AspectRatio=0.0
// Weld=true
// Display=shadedwithedges | shadednoedges | wireframe
// ExpandedDialog=false
gd.saveAs( FBXFileName, 'NoUI=true;Angle=8.0;Weld=true;MaxLength=4;Output=quads' );
// Let's clear out and suppress any save changes prompt again.
gd.fileNew( true );
Thanks for any help!
