Viewport causing an app hang
9688.2 In reply to 9688.1
HI LocusDio, it's likely to be a video driver bug. Probably the first thing to try is to see if there is any newer driver available, check directly at the Nvidia web site, not through Windows Update.
If there isn't then another thing that might help would be to try rolling back your video driver, see if there is an option as described here:
https://www.nvidia.com/en-us/drivers/driver-rollback/
and also here:
https://www.tenforums.com/tutorials/60478-roll-back-driver-previous-version-windows-10-a.html
Another thing you can try is in MoI go to Options > General and push the "Edit .ini file" button. Inside moi.ini find the line inside the [View] section that says DisplayThreadLimit= and set it to DisplayThreadLimit=1 .
Do any of those things make any difference?
