Viewport causing an app hang
9688.1
I'm currently experiencing an extremely inconvenient array of crashes (hangs) when i switch between viewports within MoI.
It looks like I can only swap my viewports ~30 before the application hangs and makes it very difficult to work. I'm not exactly sure it's 100% a fault of MoI's since I can't seem to identify anyone else having this issue, however MoI is the only application I've used regularly where this is even an occurrence.
This didn't start becoming an issue until I updated both Windows and my Graphics driver in the middle of January.
Specs, if it helps:
Windows 10 Pro
Version 1903
OS build 18362.592
AMD Ryzen Threadripper 2950X 16-Core Processor 3.50GHz
64GB Ram
GeForce RTX 2080 Ti
Edit: the MoI versions i'm experiencing this crash in may help:
4.0 Beta Jan-22-2020
4.0 Beta Oct-10-2019
If i need to supply anyone with any other information, I'd be happy to provide whatever I can. Crash logs may be difficult since the app doesn't crash, it just hangs. funnily enough, the app seems to still function, the UI just refuses to want to be refreshed/rendered. I can still pull up the save menu via hotkeys which has been helpful, but it's still incredibly inconvenient.
