Hi mat,
> With the INI file from my MAC to my PC, the PC is a company PC...different license. Will the Mac
> INI file work with a different license of MoI?
Yes the .ini file works the same between Mac and PC, and also it does not contain any license key inside it. So you can just copy it over.
> If so...do I delete the current MoI (configuration setting) file and install the Mac config setting file (INI)?
Yes, you want to just replace the default moi.ini file that was created on your new install with the one from your older system.
You can delete the newer one or just overwrite it when copying over it.
